tires?¿
Old Aug 5, 2003 | 01:03 PM
soon2bBlaster's Avatar
Default tires?¿
I was wonderin if the width of the tire was 6 inches and the diameter was 19 inches would it fit on a 10x5 rim or blaster rim?¿
Old Aug 5, 2003 | 01:47 PM
2000IAWarrior's Avatar
Default tires?¿
is the tires size 19x6x10.. then yes it would bit if the last number isnt 10 it wont fit
Old Aug 5, 2003 | 01:55 PM
Default tires?¿
ya the rim size is ten so i guess it will fit thanx
Old Aug 6, 2003 | 12:48 PM
Default tires?¿
so if the rim size is 10 and the tire says it will fit on a size 10 rim it will work?
Old Aug 6, 2003 | 12:55 PM
Starky's Avatar
Default tires?¿
You would think if you have a 10 inch rim and a 10 inch tire they should work, but if you have a 10 inch front rim that is supposed to take a 6 inch wide tire, I don't think you can put a 10 inch wide rear tire on that rim even if it is made for a 10 inch rim. Each rim has a range of tire sizes that can be used on them but I don't know where you would find that info.
Old Aug 6, 2003 | 05:22 PM
Default tires?¿
ok thanx ill just ask the dealer when i order them
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
