Warrior Headlight Rattle
Old Aug 6, 2003 | 01:26 PM
NLWarrior01's Avatar
Default Warrior Headlight Rattle
Hey all ...
I thought this would make a nice break from the recent War of The 450CC Quads.
The plastic grid/cover on my headlights is rattling something fierce!! Does anyone have this problem with their Warrior? Did you manage to fix it? How?
It's annoyingly loud at low speeds in like 1st and 2nd when the engine revs up a bit.
Any suggestions greatly appreciated!!
Old Aug 6, 2003 | 01:54 PM
2000IAWarrior's Avatar
nope.. never had that problem. look in ur owners manula on how to take the head lites apart.. and then u can tighten that front cover i think
Old Aug 6, 2003 | 01:57 PM
HoundDog06's Avatar
If I remember right that cover just clips on. You will probably have to get a new cover. The only way I can see that it should rattle is if a clip is broken. Check out RivaRacing.com to see a schematic of how the light comes apart.
~HoundDog
Old Aug 6, 2003 | 01:59 PM
HoundDog06's Avatar
Here's a direct LINK to the headlight schematic. Hope this helps. Let us know if you find out anything.
~HoundDog
Old Aug 6, 2003 | 02:06 PM
~HoundDog
Thanks for the info HoundDog .. I'll keep you posted if I'm able to fix it up ..
Old Aug 6, 2003 | 08:14 PM
AustinONeal's Avatar
on mine i just put a drop of hot glue on them
Old Aug 6, 2003 | 08:45 PM
Sparx277's Avatar
first thing you have to do is take off the headlight assembly,"the entire bracket" after that i think you should be able to take the light apart. sounds like you might have a broken bulb rattlin around or you just need to tighten some bolts. if you have the manual that came with the bike it should have directions, hope this helps you.
Old Aug 6, 2003 | 08:51 PM
No, it's the actual plastic guard mesh that's rattling .. I can physically see the vibrations and when I hold the cover still the noise stops. I'll have at look at it this weekend and see if I can't tighten it .. if not, then maybe a drop of silicone on it will do the trick [img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 6, 2003 | 09:04 PM
WarriorMadness's Avatar
Silicone will do the trick and not be that noticable, It would be nice if they had some rubber mounts on them..
Old Aug 6, 2003 | 09:59 PM
21Warrior00's Avatar
no I never had that problem but if u go to your local yamaha dealer and ask them for a service manual it will show u something in there.
Whitelx1
Oct 2, 2015 10:55 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
firsttimerider
Sep 20, 2015 09:07 PM
PrairieDog126
Sep 16, 2015 01:33 PM
