Rapping Piston
Old Aug 7, 2003 | 12:09 PM
Tyme's Avatar
Default Rapping Piston
I have a 98 polaris Scrambler Sport. I recently had HPD bore out the cylinder .80 over. I replaced the piston, rings and wrist pin and gaskets with the Wisco forged steel pieces. I put everything in according to the instruction manual (Brother in law is a mechanic and did most of the work) Everything was coated in 2 strock oil and meticullasily cleaned. I started the quad up and let it run for 15 mins, and then road it around the neighborhood at normal acceleration, with lots of stop and go. Within 10 mins I heard a rapping sound from the piston. I have not yet taken it back apart. Any ideas what it could be? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 7, 2003 | 12:57 PM
NCScrambler's Avatar
Did you check the ring end gap after re-assembly?? VERY IMPORTANT. I would say that is the problem or maybe the rings were installed incorrectly and may have broken.
Old Aug 10, 2003 | 03:04 PM
Tyme's Avatar
Hate to sound stupid, but, What is the ring end gap?
Old Aug 10, 2003 | 05:09 PM
Bubba297's Avatar
The bigger you go on the bore the more clearance you have to get to keep it from siezing. Wiseco pistons also need more clearance than the OEM. A piston rattle is common after boring and should be heard. Now a real loud noise is not common, but a rattle will be. Almost enough to bother you. My big bore had 4&1/2 clearance and made a lot of noise. Ring gap should be in the .015 area.Bubba
Old Aug 11, 2003 | 09:44 AM
Tyme's Avatar
Do you think this would effect a .080 bore? Will the noise subside?
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
