Scrambler Sparkplugs
Old Aug 7, 2003 | 09:53 PM
Dino's Avatar
Default Scrambler Sparkplugs
Is there an easy to change the plug in 2000 Scrambler 500?
Old Aug 7, 2003 | 09:56 PM
JWtrailblazer250's Avatar
I use the spark plug wrench that came in my tool pack that came with my ATV's.
Old Aug 7, 2003 | 09:59 PM
Dino's Avatar
yes - but they got the thing burried. Do you have to take everything off the front end to get to the plug?
Old Aug 7, 2003 | 10:02 PM
My 250 and my 300,you can reach inside on the front right side fender and there it is there on top of the motor.
Old Aug 7, 2003 | 10:08 PM
Dino's Avatar
I tried to do without removing anything and it took almost an hour and a half - I can bearly get the wrench in there - let alone turn it.
Old Aug 7, 2003 | 10:11 PM
Ok then I cant help you then,Wait for BigBadScrambler to get here and try and help you,he has a 500 scrammy too and knows a good bit about them.
Old Aug 7, 2003 | 10:14 PM
Dino's Avatar
I appreciate any help I can get - thanks anyway. I just can't believe it is as complicated as I am making it.
Old Aug 8, 2003 | 12:13 AM
trailrider500's Avatar
FIRST U HAVE TO REMOVE THE FRONT PLASTIC THEN THE GAS TANK THERES UR PLUG.
Old Aug 8, 2003 | 12:17 AM
BigBadScrambler's Avatar
Well, believe it. It is a pain in the **** to get to that plug!!! I just remove the front plastic and gas tank. I can get all that stuff off in about 5 minutes now. Here's a tip. Drill out the 2 rivits on the front of the plastic under the nose piece and replace them with bolts. It will make it a lot easier to take the front plastic off. The only other way to get to that plug is if you have the perfect combination of extensions and elbows and a small pair of hands[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 8, 2003 | 08:26 AM
USMCQuader's Avatar
I dont have to take my tank off. Using the tools that came with the quad, and the way the tank is indented on the right side, (and I have large hands), I can get in there (once the front plastic is off) and get the plug out.
It still sucks.
