Banshee carbs?
Old Aug 8, 2003 | 08:42 PM
Scramblin2002ho's Avatar
Default Banshee carbs?
My cuzin has a 2003 Banshee... It runs like S%^$ i took the carbs apart cleaned them completely there spotless. But i noticed the slides are black? is that normal? but back to my Question it will idle fine but will not rev just kinda sputters. i but fresh gas from my dirtbike into it (32:1) and no change.. what are the stock jetting spec's and what are the things on top of the carbs, and what does the **** on it do? thanks guys! Soule
Old Aug 10, 2003 | 07:59 PM
DunePilot858's Avatar
The slides are black because they are coated with an antifriction coating. The *****/screws on top of the carb adjust the idle speed. If you turned one without turning the other at an equal amount you have tricked the throttle override system (TORS) into thinking one of the slides is stuck and it will cause the bike to run like crap. Adjust the slides so they are equal and then check the parking brake. If it's not adjusted it will kick in a rev limiter and it will not rev past that set amount. If you don't understand what I have posted take it to a dealership where they know what to do.
Old Aug 12, 2003 | 11:53 AM
atvrules's Avatar
sounds like the slides are in backwards, there is a left and a right, the same thing happened to a friends 03 banshee.
Old Aug 12, 2003 | 09:33 PM
WyoDuner's Avatar
Slides are in backwards or the TORS or parking brake switch is activated. Unplug the TORS box under the tank, near the front on the left. Make sure the parking brake switch isn't stuck - give it a few wiggles. Make sure the cut-out on the slides is towards the rear.
I'll bet money it is one of those problems.
Old Aug 12, 2003 | 10:07 PM
crispy's Avatar
and if all that doesn't work, last resort to the spark plug(s)
the same thing happened to my blaster but it was the parking brake
Old Aug 12, 2003 | 10:28 PM
Don't forget to look for the tube connecting both carbs together. It will run like crap without it.
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
