Warrior clutch lever HELP
Old Aug 9, 2003 | 12:17 AM
OneWheelWheelie's Avatar
Default Warrior clutch lever HELP
HOw do i make my clutch lever loser irt is so dam hard to pull in i have to use my hole hand i whant it nice and smooth so i can just use one or two fingers any tips
Old Aug 9, 2003 | 12:50 AM
2003warrior's Avatar
maybe u need to oil your cable that might help
Old Aug 9, 2003 | 12:58 AM
RacerRob's Avatar
2003...thats the same thing i'm thinkin'. The Warrior lever doesn't or shoudn't be that tuff. Or maybe the cable is pinched somewhere making it harder to slide..[img]i/expressions/face-icon-small-cool.gif[/img]
Old Aug 9, 2003 | 01:10 AM
i did oil it but it didn't make much of a difference anythuing else that i could do any adjustments
Old Aug 9, 2003 | 01:34 AM
i dont know of any other adjustment other than the length.....if u oiled it plenty then its gotta be pinched either that or u got some stiff @$$ clutch springs but on my warrior i aint got no problem pullin it in with 2 or even 1 finger
warrior007's Avatar
There are no adjustments. I found that a new clutch cable works wonders, if it was never lubed or lubed with the wrong stuff it will never be an easy pull. Also if you clutch basket is all tore up it will be hard and a little notchy.
Old Aug 9, 2003 | 01:52 AM
what should i oil wear should i oil what kind of iol u say replace the clutch cable how much canadian
Old Aug 9, 2003 | 03:08 AM
on my yz80 the clutch cable was a little sticky so i used 3in1 oil
i put it in one end till it came out the other end it took more than a couple of drops actually i used alot
i think i got a little to much oil thought but its like i got a new cable.....even though its 20years old lol
i also used it for my pedel bike for the brake cable so far they all work great
Old Aug 9, 2003 | 01:28 PM
how do i check if my cable is pinshed and i poor the oil in and wait until it comes out of the cable is that right
Old Aug 9, 2003 | 03:42 PM
just follow the path of the cable it should be curved nicely down to the clutch lever
if its got a sharp bend or an angle that would make the cable pull harder
i took my cable off and put oil in it and moved the cable up and down inside of the casing to get it lubed up good
