WHAT DOES A BLINKING ReVERSE LIGHT MEAN?
Old Aug 9, 2003 | 01:01 AM
INSeaRChOFDUNez's Avatar
Default WHAT DOES A BLINKING ReVERSE LIGHT MEAN?
what does a blinking reverse light mean on a raptor??? i had just gotten back from trying out new jets and the reverse light was blinking and my quad was idleing higher than normal.
Old Aug 9, 2003 | 01:17 AM
sixsixT's Avatar
If you idle high for a few minutes without moving the light will blink, it's normal.
Old Aug 9, 2003 | 01:18 AM
wildchild660R's Avatar
have you tried adjusting your idle screw? The reverse light on mine does that too. I think its just kind of an error thing. I just down shift and get it back into neutral and it turns off then. Nothing big I dont think
RacerRob's Avatar
It just means the quad is revving too high for too long..basically. Just turn it off and start it again. Or get on it and ride it up and down the driveway once. Its just a high rev warning....[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 9, 2003 | 01:22 AM
So let me figure this out guys..... If my reverse light is blinking that means it idling to high? Im confused, I thought it just meant it was kinda in between reverse and neutral (error I was guessing)
Old Aug 9, 2003 | 01:29 AM
RacerRob's Avatar
You got it!!....Strange but true....[img]i/expressions/face-icon-small-cool.gif[/img]
Old Aug 9, 2003 | 01:32 AM
well I learned something new today. Thanks racerbob
Old Aug 9, 2003 | 01:34 AM
RacerRob's Avatar
Old Aug 9, 2003 | 01:43 AM
so does follow the light blinking by idleing high too by itself? i turned the screw out to when it was at a good ide and the it would idle high and my pipes got hot a hell. so i put the fan to work full time by tappin in to it.
Old Aug 9, 2003 | 01:54 AM
sixsixT's Avatar
Just idling high shouldn't set off the light, you also need to not be rolling. There is a speed sensor on the engine. So if the ECM senses a higher than normal RPMs and no speed from the sensor the light will blink.
