Which jet?
Old Aug 10, 2003 | 05:41 PM
Badazpred's Avatar
Default Which jet?
Whats up people, Ok i have a few questions and to all those that reply it will be greatly appreciated. I just put a pro circuit t4 slip-on on my predator and it starts to stumble at the end of every gear, i guess it would be the top end. So im going to attempt to jet this thing tomarrow and i need to know which jet this carb uses. I know that it uses the round jets but is it the large round ones or the small round jets. Also if anyone could give me a size to start with at about 2500 to 3500 feet in elevation it would be a huge help. I also have a k&n if that matters any. Please someone help me out! Thanks
Old Aug 10, 2003 | 11:37 PM
RookWV's Avatar
Default Which jet?
I'd say your best bet would be to call the manufacturer of your pipe and ask them.....they should be able to help out quite a bit....or at least give you a good starting point.
Old Aug 11, 2003 | 11:43 AM
haulin's Avatar
Default Which jet?
They are small round jets. I have the dyno Jet kit and it tells me with a pipe and filter to use the 150 main for sea level and 145 or 146 for 3500 ft to like 6000 ft if I remember correctly. They also give you a different needle jet, but I'm not sure if it's a different size from the stock one. If I were you, I'd try the 145 or 6 and start with that. def. not over 152.5 main though. Hope this helps.
