Fan will not turn off???
Old May 26, 2000 | 02:06 AM
pete/ny's Avatar
I just got back froma GREAT 400 mile atv ride in northern Ontario and for the entire trip my fan on my 300 Explorer ran continuosly! Is there a relay or some type of device which turns this fan on and off? On the other hand my brother inlaws 300 Explorers fan never went on at all despite some very hot and humid weather, but his must have been overheating as it had a serious case of the low end BOGS! I called a dealer and he said that the fan itself was defective and at the price he quoted me, maybe I would try and corect this problem myself. Any help will be appreciated before I have to go to the dealer.I can!t beleive that the fan is bad as it ran for some 400 miles without ever stopping! Thanks.
Old May 26, 2000 | 01:02 PM
ChopperBill's Avatar
Temp sending unit is mounted behind cylinder head.Remove one of the wires, if fan quits running you need a new sending unit. If not could be the pair of wires going to the unit are shorting one another. Trace and fix. Shouldnt be to hard to fix. If the fan is running its hard to believe its defective.
Old May 26, 2000 | 01:03 PM
Tim1's Avatar
It's not the fan the termal switch screwed in the rad decides when the fan comes on and off.Look at your Rad when you find two wires that lead to it thats your thermal switch.
Old May 26, 2000 | 01:11 PM
Tim1's Avatar
Opps! I just took a look the thermal switch is on the top left side of the engines on these things.There is a thermal sensor on the rads top right backside that may also be the promblem but that may only be for the hight temp light.
Old May 26, 2000 | 01:19 PM
Deej's Avatar
Pete,
These guys have the right idea. The fan is controlled solely by that thermal switch. When the engine heats up the switch closes and turns the fan on. As suggested, simply pull one or both of the wires off the thermal switch. If the fan stops, the switch is defective, replace it. If the fan still runs then there is a short in the wiring somewhere. I also agee, should not be hard to find. The fan motor is fine.
Good Luck
DJ
Old May 26, 2000 | 06:11 PM
Pfelect's Avatar
On my Xpeition the sensor is on the lower right hand side of the radiator, if youre siting on the machine. Under the "hood" there should be a connector that leads to the sensor. You can unplug it there to see if the fan shuts off. I have the opposite problem, the fan wasnt coming on so I unplugged the connector and "jumped" across the 2 wires so that it would be on all the time. I have the new sensor, just havent put it on yet. If yours takes the same sensor be prepared to pay about $50 for it.
Old May 26, 2000 | 11:33 PM
will's Avatar
I had the same thing happen to me on my 2000 Boss. I took it to my dealer and he said that it was a wire that was pinched he fixed it for like $22.00.
Divergent12
Dec 30, 2017 08:33 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jul 30, 2015 09:39 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
