How to adjust preload on vforce rear shock
Old Aug 12, 2003 | 12:59 PM
mjohnson97045's Avatar
Default How to adjust preload on vforce rear shock
How do you adjust the preload on rear Vforce shock.
I can see the notched rings to rotate to compress the spring but can not get a tool in there to do it.
Old Aug 12, 2003 | 02:06 PM
DirtDragon's Avatar
Long Screwdriver and a hammer will work fine. Just hit the top ring so it will loosen. Once it is loose put the machine up so wheels are off the ground and spin the bottom ring until there is very little tension on the spring. IF you go too far the spring will move to the right and left when you jump. This will ruin the shock I'm told. Good luck!
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
07Redrider400
Jul 25, 2015 05:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
