04 Sp 500 over revving at 45 mph... help
Old Aug 13, 2003 | 02:16 AM
mudbug04's Avatar
Default 04 Sp 500 over revving at 45 mph... help
i rode my sp 500 today and i was going 45 mph and it was doing fine... untill i decided to giver sum more throttle and then it started revvin at about 6200 rpm plus it wasnt really accelerating... before this like a day before it was doing 53 mph easy... i dont know if sumthing came loose or what.. please help
Old Aug 13, 2003 | 02:40 AM
scrambler123's Avatar
it sounds like clutching to me try pulling off your clutch cover and seeing if everything is ok
Old Aug 13, 2003 | 09:13 AM
Sep1's Avatar
As someone stated before the white plastic nut for the EPS is loose. More common on the 600, but can happen on 500.
Take cover off and tighten nut on the secondary.
Old Aug 13, 2003 | 10:51 AM
Moodster's Avatar
Check the nut,but also check torque of bolt holding the clutch on,45 foot pounds to 50.
Old Aug 13, 2003 | 09:37 PM
mudbug04's Avatar
hey uh i had the clutch cover off.. and i cant find that plastic nut??? any help?? is it outside of the cover or inside?? thanks
Old Aug 13, 2003 | 09:40 PM
mudbug04's Avatar
also...(sorry about the multiple posts) [img]i/expressions/face-icon-small-smile.gif[/img] when my problem happened ... its started revvin so i thought i would turn the idle **** so it idled down it did.. but when i gunnned it again it overreved again??? so if i fix this how much will it help?
thanks
Old Aug 14, 2003 | 09:12 AM
Sep1's Avatar
What year SP do you have, May be I should have asked you first. If you do not have EBS, it sounds as if your belt is slipping at high RPM's.
Old Aug 14, 2003 | 01:58 PM
Sep1's Avatar
Da, Just noticed on your name 04 sportsman. Try and remove a shim (washer) from behind the secondary, if there are more than one perhaps this is preventing shift-out.
Old Aug 14, 2003 | 11:57 PM
mudbug04's Avatar
yea it is 04 sportsman 500 ho with ebs... im going to the mountains on fri... tomorow and i had a buddy that was leaving early to get a good camp spot.. take my quad with him... so i wouldnt have to haul it so i will get back to you guys on monday morin when i get back.. l8r.. thanks a lot so far
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
bvolks
Sep 13, 2015 12:57 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
John Reed
Sep 9, 2015 03:46 AM
