500 scrambler idles up
Old May 26, 2000 | 07:48 PM
stevie's Avatar
I need your help cause im goin ridin tomorro but when i installed my hpd pipe it will not idle down it just revs really high what is wrong and how do i adjust it. Please help soon
Old May 26, 2000 | 08:47 PM
stevie's Avatar
What the funk is goin on i always see you poston someone elses prob but u dont even look at mine
Old May 26, 2000 | 09:36 PM
2000Scrambler's Avatar
if u rejeted u'r carb u probally got the wrong jets or u'r idle screw on the side of u'r carb is turned up so all it does is give it the gas with out u giving it the gas thats my guess.
Old May 26, 2000 | 10:49 PM
ATV_MAN's Avatar
Yea just turn the idle screw down that should help. If that doesn't help....that's all I know LOL
Old May 27, 2000 | 07:47 AM
Mike Chero's Avatar
Stevie,
If turning the idle screw doesn't help, you may have to go for a richer pilot jet. I'd go up one or two sizes to see if it'll help. Also check for leaks in the intake, between the carb and the cylinder. That should solve your problem!
Old May 27, 2000 | 09:41 AM
stevie's Avatar
The idle screw is all the way down it was because the way the throttle cable was stretched out but now its fine. Thanks anyway. It only took 3 hours.
Old May 27, 2000 | 11:14 AM
stevie's Avatar
I started it this morning and it was idlein perfect then it just turned off now it wont start at all please help
Old May 27, 2000 | 11:46 AM
ATV_MAN's Avatar
That's why I don't buy polaris atv's, they need fixi'n all the time. LOL
Old May 27, 2000 | 04:30 PM
Mike Chero's Avatar
Stevie,
Run ther standard tests, for spark, compression and fuel. This should narrow it down to one area in which to concentrate on.
Old May 27, 2000 | 06:27 PM
Rictor774's Avatar
Yeah Mike's right you need an richer pilot jet, the idling caused your spark plug to foul.
Later
