500 scrambler idles up
Old May 27, 2000 | 09:19 PM
stevie's Avatar
i had the idlein perfect then it stalled so i took off the carb. An there was no gas in it but the other time there was so i took off all the gas lines and they where bone dry so i pulled the lines off cleaned them with carb cleaner and there wernt clogged. so i put them back on and tryed again but they where still dry and no gas in the carb. So i traced the line back to where it went and it goes to something the is attached to the frame it is close to the rad cap What is it and can it have anything to do with that if i cant figure it out it will go to the dealer
Old May 27, 2000 | 10:41 PM
stevie's Avatar
Should my dealer carry pilot jets.
Old May 28, 2000 | 10:25 PM
hawk045's Avatar
You might try adjusting the etc. There is a boot on the throttle cable just below the etc. My 335 idled high when i turned the steering to the left.I adjusted it no more problems.
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
