P650 Cold Natured? Starting Tips?
Old Aug 15, 2003 | 07:10 PM
therock's Avatar
Default P650 Cold Natured? Starting Tips?
I am 25 miles north of Atlanta. It's hot & Humid. Compared to my 2000 Kodiak the stating procedure of the 650 leaves little to be desired. On the Kodiak I just move the choke half way and BAM I get a high-ish idle start up.
The Choke on MY P650 is usless for starting. If I try to use it, it makes things worse. I have to turn it over with a little throttle. It will sputter and if it stalls and I restart it I get a loud TAPing or Clacking from the engine area for a moment or two. I can rid of it by a little throttle bump. What's that?
How do your P650's start up?
Old Aug 15, 2003 | 07:40 PM
KISSSOFDEATH's Avatar
You probably wont believe this but my P650 will start a lot easier with the pull rope than with the button. Im serious, it starts everytime on 2 pulls or less. No throttle or choke. Try it.
Old Aug 15, 2003 | 07:58 PM
Nightryder888's Avatar
the electric starter works fine on mine it has started the first push of the button 98% of the time. its not so bad in the summer but in the winter it takes a good 3-4 min. of warming it up before it will idle correctly
MikeyBoyesq
Nov 27, 2020 02:44 PM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
Big600twin
Jun 10, 2015 03:01 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
