hpd chain tensioner,please help!!
Old Aug 16, 2003 | 03:27 PM
scrambler420's Avatar
Default hpd chain tensioner,please help!!
hey guys i just got my chain tensioner from hpd and it doesnt look like its going to fit right..when i put it in place where it should go,it doesnt look like the chain is going to ne centered on the roller??please help..if anyone has some close-up pics that would be cool..thanks a bunch...
Old Aug 16, 2003 | 04:08 PM
CED's Avatar
CED
Check out pic #2 in my gallery and see if it is like your's.My bike is a 96.Hope this helps.
Old Aug 16, 2003 | 04:30 PM
according to hpd the chain tensioner is suppose to be bolted to the swingarm..i guess the 96's are different?thanks for the help
Old Aug 16, 2003 | 04:35 PM
Cowboy35's Avatar
Is it a concentric drive??? This might make a difference where it is mounted.
Old Aug 16, 2003 | 04:59 PM
yes mine is concentric drive..i had to cut off the metal mount for the chain guard and it seems to line up somewhat close...the directions say to install it right behind the cross member,just not sure how far back it should be
Old Aug 16, 2003 | 05:24 PM
BigBadScrambler's Avatar
Hey, I got close up pictures on my site of where it should go on the concentric drive scramblers. It should give you an idea. Also, I had to use some washers for spacers and space the mounting bracket about 1/8th" away from the swingarm cuz the chain was hitting the bolt for the spring. Also, I had to grind down the spacer for the roller to get the chain in the middle. If you take off the roller, it makes it easier to mount the bracket. Hope this helps
Old Aug 16, 2003 | 05:44 PM
250EXcited's Avatar
I just installed mine today, but I got it from RCR. I disconnected the spring from the roller so there would be no tension while I aligned it. Made it alot easier. Move the tensioner too far forward and the chain will ride on the outside of the roller. Move it too far back and the chain will rub the spring. Align it without the spring attached and you'll be good to go.
Old Aug 16, 2003 | 06:12 PM
talonhawk's Avatar
To add to this, make sure that the chain is centered more to
the outside of the wheel and not dead center. I have one on
my 99 and had one on a 00 TB. The chain rubbed away the
grease fitting for the wheel on the 99 so on the 00 I moved
the tensioner just alittle further back on the swing arm.
Old Aug 16, 2003 | 06:55 PM
RickRitter's Avatar
There are 2 different tensioners .
# Atvct ----> fits pre concentric drive quads .
#Atvctc ----> fits all concentric drive models .
Note this ---> tensioners for pre concentric are a Silver colored plating , tensioners for concentric drive models have a GOLD colored plating on the mount plate .
Rick
Old Aug 16, 2003 | 07:06 PM
Maddog419's Avatar
Make sure the chain tensioner is for a concentic drive. Non concentic will not fit. HPd sent me the wrong one,hope this helps.
