kasea 50cc
Old Aug 16, 2003 | 08:16 PM
Sandattic's Avatar
Default kasea 50cc
my sons kasea 50 dies out after about 1min of riding. i messed with all the screw adjustments on the carb, the small one, the larger one and also the idle screw. does anyone know what they all should be at? thanx
Old Aug 18, 2003 | 03:17 PM
Modified50ccDad's Avatar
Default kasea 50cc
Sounds like a fuel problem. It may be that a vacuum is forming within the fuel lines. Unscrew the gas cap and restart. When the quad stalls pull the fuel line off the quad to see if gas is flowing. It may also be a plugged gas filter. Let me know how it goes.
Old Aug 18, 2003 | 06:15 PM
Sandattic's Avatar
Default kasea 50cc
ill try that today and get back
Old Aug 18, 2003 | 08:26 PM
mascman's Avatar
Default kasea 50cc
Another idea may be the electric choke. My daughter's quad has to be very warmed up for it to run smoothly. While it was running badly, I unplugged the choke and it ran great...it just seems finicky.
Anyone know if these electric chokes are prone to do that?
Old Aug 19, 2003 | 04:32 PM
Default kasea 50cc
I have also had probs with the electric chokes. I switched to a 20mm carb, removed the oil injection and never had a prob since. I also know several other dads with the electric choke prob.
Old Aug 19, 2003 | 09:44 PM
Sandattic's Avatar
Default kasea 50cc
well havnt figured it out yet. ill try to diconnect the choke now and see what happends. do u guys know what your airmix screw and idle screws r set at?
Old Aug 19, 2003 | 10:18 PM
Sandattic's Avatar
Default kasea 50cc
well what do u know [img]i/expressions/face-icon-small-happy.gif[/img] it is the choke. so what should i do from here? do just leave it disconnected or what ? thanx for all your help
Old Aug 20, 2003 | 12:37 PM
mascman's Avatar
Default kasea 50cc
I'm glad you located the problem, from what you were saying I thought that was it.
I am thinking of just putting an inline switch on it. Flip it on to get it running and then flip it off when it starts to stumble...almost like a manual choke. You could probably get some sort of handlebar mounted switch.
Try warming it up real good unplugged and then plug it back in. Her's seems to be fine once it is very warmed up and I just want to see if your's is the same way.
Does anyone know how the choke senses or what makes it adjust itself? Is it reading off of air temp or density of the fuel coming into the carb or something?
I think installing that switch may be my solution for now. I'll replace the carb when she's ready for more power.
As for the screws, I don't remember since I adjusted them after I put on the K&N.
Old Aug 20, 2003 | 04:18 PM
Default kasea 50cc
Mascman,
If that switch idea of yours works I'd appreciate it if you let us in on how you did it. Thanks
Ramman1
Aug 11, 2022 01:53 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
firsttimerider
Sep 20, 2015 09:07 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
ghost3
Jul 19, 2015 08:46 PM
