What is the difference in these oil ratings......
Old Aug 22, 2003 | 04:05 PM
RaptorRidr660R's Avatar
Default What is the difference in these oil ratings......
I use honda 4-stroke motor oil in my raptor. I bought another quart today because I have to open up the side case and I will lose oil. I bought the same oil as always, but the rating went from 10w 40 SG/SF to 10w 40 SJ....... What is the difference? Can I mix it with the SG/SF thats left in the engine or should i drain it al and use all SJ? Thanks
Old Aug 22, 2003 | 04:20 PM
Raptorx44's Avatar
I think you will be ok. Those are standards. Stay away from energy conserving letters if you ever switch to using automotive oil due to clutch slippage.
Old Aug 23, 2003 | 12:33 AM
duckdiaz's Avatar
SG/SF...SJ
API ratings come two ways. The "S" rating indicates service and is usually meant for normal passenger vehicles. The "C" rating indicates commercial and is meant for rough, extended-use vehicles like taxi cabs and trucks. Each API rating comes with another letter to indicate how well it performs. SA represents the lowest service rating for passenger vehicles, and CA represents the lowest rating for commercial vehicles. At present, the API rating for the highest rated oil is SG and CE. But remember, you have to consider what conditions you are running your vehicle under. For example, if you are racing your engine, or running under high demands, like off-road driving, you might want to consider the "C" rating instead of the "S."
Old Aug 23, 2003 | 12:56 AM
KILLERCUDA's Avatar
That SJ Covers everything before it such as SA SB SC SD SE SF SG ect all the way until SJ.
Old Aug 23, 2003 | 02:52 AM
Cool, thanks guys, that helped alot!
Johnny Mac
Aug 15, 2019 03:13 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
fredrikrosen
Sep 28, 2015 09:58 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Steeldon
Sep 9, 2015 09:38 AM
