Rear breaks &bad noise
Old May 29, 2000 | 10:27 PM
Lucis's Avatar
when i hit my rear break there a real loud grinding noise.........i know the break pads cant be worn yet only had the quad a month
it a 400EX any idea what it could be
Old May 29, 2000 | 10:41 PM
lovinhonda's Avatar
Is it just one wheel or both?
Old May 29, 2000 | 10:48 PM
Lucis's Avatar
i cant even tell where it coming from but it doesnt seem to be coming from one of the wheeles seem to be more near the frame or chain .I cant really tell it just started last weekend at wayen forest.I thought rock or mud just got in the break pad clean it real good but today was still doing it.Only when i hit the rear breaks not at all on fronts
Old May 30, 2000 | 10:50 AM
lovinhonda's Avatar
well if it is you'r chain, it is sliping off the
sprocket. you would haft to tightin the chain. now for the frame i don't think that could be. I mean how could it be,the frame?
Old May 30, 2000 | 05:54 PM
Mike Frey's Avatar
Could be your chain. Tighten it to 1.5" freeplay. Try cleaning it. If it is especially bad, spray some contact cleaner on the chain and with a towel, rub it off real good. Then lube the chain. It is best to lube (and clean if neccessary) the chain after a ride, and leave it for a while to let the lube soak in. The noise could also be sand and grit on your rear sprocket.
Old May 30, 2000 | 09:53 PM
Lucis's Avatar
i own a real good power washer.....so i powerwash my 400 after ever ride and lube the cain back up it real clean no sand or dirt on the disk breaks,but i did notice the chain seem to be lose but in a weird way the top of the cain isnt lose but the bottom part of the chain is..it look like it rubs the stock skid plate could that be the noise i hear when i hit the rear breaks.the chain hitting the skid hard
Old May 30, 2000 | 10:19 PM
puddding's Avatar
yup...... check out the skidplate
they are strong but not that strong
Old May 31, 2000 | 09:52 PM
Lucis's Avatar
thanks for the post.found out what was worng.
dont ask me how i do not know but in a short amout of time 3 weeks of riding my rear break pad were worn down to the metal of the pads .i use my frount more then anyting so all i can guess is all the mud and dirt i have been stuck riding in, must of got into the break pads and ate them off
Old Jun 1, 2000 | 12:26 AM
Mike Frey's Avatar
My rear pads are shot too. I have a pair of EBC to install but I am having trouble bending the lock tab back. I was holding the caliper with one had and trying to bend the tab back with a Leatherman. The Leatherman slipped off and I stabbed myself. When I was washing it off with water, I fainted. Afterwards, I said screw it and put off installing them. I will change them this weekend.
greg74
Sep 10, 2019 03:03 PM
Divergent12
Dec 30, 2017 08:33 PM
ronnierhino06
Nov 9, 2015 12:56 PM
clsharky
Jul 13, 2015 02:07 PM
D-Hagz
Jul 4, 2015 02:19 AM
