carburetor(needle clip) help!!!
Old May 30, 2000 | 04:14 PM
decoyrth's Avatar
How do you adjust the needle clip?? how do you get to it. I have a keihin 39mm pwk, and I don't get how to adjust it?? please help, thanks
Old May 30, 2000 | 04:37 PM
retro's Avatar
To adjust the needle clip you;
1)unscrew carb cap
2)pull out slide assembly
3)disconnect cable from top of slide
4)turn nut 180 degrees counter clockwise
5)nut and needle should fall out if turned upside down
6)take clip off of needle move it up a notch for more lean or down a notch for more rich
7)slap her back together the same way you took it apart
wrencher82
Sep 24, 2015 03:39 PM
black_thunder
Sep 22, 2015 07:59 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Hw00d
Sep 10, 2015 08:53 AM
