wobble
Old Aug 29, 2003 | 01:38 PM
Nookums's Avatar
Default wobble
Hello fellow V-Forcerz,
My question is: Anyone out there have a wobble at high speeds? It seems as though my right rear tire is deformed. When the quad is parked I can see a difference between the two rear tires. The right tire is ballooned while the left tire is flat across the top. While cruising I can see the right rear tire wobbling. Are the tires covered under the warranty?
Old Aug 29, 2003 | 02:28 PM
Ball's Avatar
Default wobble
Check the air pressure. I bet the ballooned tire has a few more pounds of air in it.
Old Aug 29, 2003 | 04:10 PM
Nookums's Avatar
Default wobble
Air pressure is spot on as required by the owners manual and service manual. I can tell you this though, I started noticing the wobble after a day of riding an oval making constant left turns. It could have put alot of pressure on the right side tire sidewall.[img]i/expressions/face-icon-small-disgusted.gif[/img]
volsgo30
Jun 4, 2015 06:07 PM
Chieftam
Nov 10, 2002 11:06 PM
swivel
Jun 21, 2002 11:06 AM
jskoland
May 30, 2002 11:30 AM
vugger
Apr 10, 2002 09:14 AM
