Big Red dies when throttle is hammered.
Old Aug 29, 2003 | 10:39 PM
thebutelr's Avatar
Default Big Red dies when throttle is hammered.
I've got a 250ES big red and when i just start it up or even after it has been ridden for a while when i hammer the throttle while in neutral it just kills itself down. I was wondering if it could be my head gasket (cuz it is cracked) or something on my carb. Help would be much appreciated. Thank you.
Old Aug 30, 2003 | 11:43 PM
dragracer789's Avatar
try adjusting your air screw on your carb. It has a big roll in throttle response.
Old Aug 30, 2003 | 11:55 PM
thebutelr's Avatar
Are you positive its not my head gasket? And how much should the carb screw be adjusted? Please respond.
Old Aug 31, 2003 | 04:22 PM
Is there air blowing out of the head gasket?? If there is there will be a big loss in compression witch will lead to loss in throttle response and overall power. If it looks like theres no air coming out or being sucked in then your carb probably needs to be adjusted...
If air is blowing out or sucking in just replace the gasket.
P.S- Usually air screws should be about 1 1/2 tunrs OUT
Old Sep 1, 2003 | 02:50 AM
heehaw's Avatar
on your carb problen i had one do the same thing it waqs the choke it looked like it was released all the way but it wasent un screw from carb and clean it i think that will fix your prob if not e-mail me we will fig something out.
proud owner
5 250sx
1 250es
1 250r
1 185
1 200s
1/2 250sx still building
Old Sep 2, 2003 | 08:07 PM
bigreddy's Avatar
Some things to consider. Pilot jet may be partialy plugged. Air screw in need of adjustment. Old gas, and or, water in the gas. Ive seen many bikes come and go with either one or more of these problems that had a bog right off throttle valve pickup
gorylewis
27
Oct 4, 2015 05:22 PM
Knackknack
Aug 19, 2015 07:45 AM
house1
Aug 9, 2015 10:49 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
