Changing Oil in a 500 ho
Old Aug 30, 2003 | 08:04 PM
heck's Avatar
Default Changing Oil in a 500 ho
Do you have to install a new seal around the drain plug each time you change your oil? The manual says to replace the washer seal and to disconnect the lower oil delivery hose to clean it and the screen. Then, it says to Loctite the fitting back. Is this necessary? Thanks for the info. They charged me $23 dollars for 2 quarts of oil and the filter at my local dealers. Has anyone tried any other kind of oil?
Old Aug 30, 2003 | 10:07 PM
highwayman's Avatar
I use Castrol syntec 5w50 oil because it is easy to get and the last oil change (my first) I did not clean the screen because I figured the spin on filter kept the screen clean. As for the brass or copper washer on the oil resivoir I don't change that till it leaks same as the cars I've owned in the last 25 years.
Old Aug 30, 2003 | 10:09 PM
highwayman's Avatar
P.S. I would us the polaris lubes untill the warrenty runs out then look for more cheaper or more accesable lubes.
Old Aug 30, 2003 | 10:40 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Mobil 1 is an excellent alternative to the polaris oil and Wix and NAPA have oil filters (part #s 5138/1358) that are much cheaper. Be sure to use a sythetic oil.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
