HMF Jetting????
Old Aug 31, 2003 | 04:26 PM
AKpredator's Avatar
Default HMF Jetting????
Need a little help fine tuning this beast. Have the HMF slip-on and a K&N drop in no air box mods. Having problems 3/4 to full throtle. Plug is tan to white in color. Running at sea level and temp is is around mid forties. Where should I start, I haven't did anything to the carb yet.
Old Aug 31, 2003 | 04:44 PM
BigScary's Avatar
go up 2 sizes on your mains.........
if the plug is white you are lean......
Old Aug 31, 2003 | 11:47 PM
ILPRED500's Avatar
I had the same set up, I used a 155 main jet, and the mixture screw 3 1/2 turns out, it worked great.
Good Luck,
Ryan
Old Sep 1, 2003 | 08:22 AM
jsyi's Avatar
Im at about sea level and I was running a 167.5 and 50. No adjustments to the air screw or needle position.
Old Sep 1, 2003 | 04:49 PM
pudljumpr's Avatar
I have the drop in and HMF Slip on and am running the 155. If anything it reads a little rich, but I had been riding in some upper 80-90 degree days. But it does sound like you need to go up 1 size, like a 157
Old Sep 2, 2003 | 12:31 AM
AKpredator's Avatar
Thanks guys. went up to a 155 and all I can say is wow!!!! Hope to have time tommorrow to check the plug and see how things are.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 2, 2003 | 02:51 PM
pudljumpr's Avatar
You went up to a 155?? As in you never changed it? HMF recommended switching to a 155...now that you have that you should be jetted darn near perfectly!
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
