Scrambler 500 Chain
Old Sep 1, 2003 | 05:32 PM
Aguywhocanneverbuyagoodquad's Avatar
Default Scrambler 500 Chain
Hey does anyone own a scrambler here? I need to tighten the chain but then again since its loosen maybe the chain is wearing out or something? Heck I just got my scrambler and i don't know how to do any matience on it yet.
P.S
Can't find manuel
Old Sep 1, 2003 | 06:07 PM
robne68's Avatar
Well, assuming all are the same as my 03, just loosen up the 4 bolts that clamp the axle in place and use the big wrench supplied in the tool kit, or whatever you have available, and rotate the axle to adjust the tension. The clamping surface is eccentric to the axle so it has a cam effect. Good luck.
Old Sep 1, 2003 | 09:31 PM
RookWV's Avatar
Pretty sure you have to loosen the brake caliper bolt as well.....
Easier than using the spanner wrench is to put a punch pin in the small hole in the axle housing so it locks it down and then roll the quad back to tighten it and roll it forward to loosen it (use something very stout, I broke a cheapo screwdriver in mine.....but you still have to loosen the bolts mentioned above and you must be careful when tightening them back up (torque the eccentric bolts to 30ft/lbs and the brake caliper bolt to 12ft/lbs (I think)).....if you overtighten you may cause premature bearing damage.
Also, you can only move the axle back until it hits the stops on the housing....then you have to turn it forwards and start from scratch....
Good Luck.....if you have any other probs just post on here....someone will know..
Old Sep 2, 2003 | 12:16 AM
BigBadScrambler's Avatar
You can get a service manual from your dealer or from pure polaris Also, you can get a chain chain tensionor from HPD and you wont have to worry about it getting loose again. If it is the original chain then it definately may be time to get a new one
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Matt123
Sep 29, 2015 01:29 AM
kbazzy
Sep 26, 2015 11:26 AM
exmotocrosser
Sep 26, 2015 08:18 AM
