lost power to all accessories including 4x4
Old May 31, 2000 | 01:03 AM
scramblinman's Avatar
does anyone know if both of the yellow wires comming from the stator/magneto/generator(whatever you want to call it) are supposed to be hot while the engine is running? Mine are not. i lost all power on the circut board in the front of the machine. but i do have two wires with power to the coil so the engine will still run.
Old May 31, 2000 | 03:58 PM
MNT's Avatar
MNT
If your key switch is moved slighlty while the engine is running, all accessory power and AWD is shut off.......maybe look in this area.
Old May 31, 2000 | 04:49 PM
ChopperBill's Avatar
I assume you mean a yellow and red\yellow wire. They go to the regulator. There should be a minimum of 7 amps coming from them at an idle, dont increase the RPM. If you test it only do for a few seconds because it puts a full load on the alternator windings. If you dont have any reading the stator needs to be replaced. You should really get a manuel if you are doing your own work, saves alot of time.
nachop
Feb 14, 2018 06:57 PM
Atvnewb88
Aug 19, 2015 02:22 AM
Atvnewb88
Aug 13, 2015 06:48 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
toonces
Aug 5, 2015 05:55 PM
