Question about my new kodiak
Old Sep 2, 2003 | 09:00 PM
Russo03's Avatar
Default Question about my new kodiak
i just bought a yamaha kodiak and i tried to put it in diiff lock mode in high gear and it started to stalli took my finger off the gas and it stalled why is this happining
Old Sep 2, 2003 | 09:07 PM
SoXx's Avatar
Not quite sure why this is happening I have a 04' Kodiak and have used it in Diff. Lock in High and Low gear with no problems. Does it stall only when you do this? Or has it stalled and now will not start again. Don't take this the wrong way but have you turned on the gas? On the side of the machine. The only reason I say this is because when I got mine I left it in the off postion and there was enough gas left in the line to drive around a bit then stalled out. I then remembered about the gas shut off switch.
Kevin
Old Sep 2, 2003 | 09:09 PM
Russo03's Avatar
Yes the gas is on all the way. The only time it stalls is when i'm in high gear with the lock on. It works in low with the lock on
Old Sep 2, 2003 | 10:11 PM
Kodiac400's Avatar
It kind of sounds like reds problem. There is definitely something screwed up there. Does it only do it in Diff mode or does it do it in regular fwd?
Old Sep 2, 2003 | 10:16 PM
Russo03's Avatar
thanks guys but i just let the quad sit for awhile and everything is working fine but i would still like to know why it was diong that
Old Sep 3, 2003 | 12:31 PM
RED5's Avatar
Yes this is the same problem I had at first I said it stalled when put into 4x4 but after thinking about it it could have been diff lock. Mine stalled and then after a couple minutes started and then again when put into 4x4/diff lock stalled again and wouldn't start for quite some time. It sucks pushing these things especially when they are new! [img]i/expressions/face-icon-small-mad.gif[/img]
Old Sep 4, 2003 | 10:35 AM
atv123's Avatar
Red - did you ever figure out the prob? Does it still do it?
Old Sep 4, 2003 | 12:01 PM
RED5's Avatar
Haven't figured it out yet, I've actually been busy the last couple of days and haven't had the time to check it out, hopefully today after work I'll try and see if the same thing happens.
Question: Is it OK to shift these wheelers into 4x4/diff lock on the go (at slow speed)??
Old Sep 4, 2003 | 08:07 PM
SoXx's Avatar
I have no idea if it is ok or not the book says now but I have shifted it at slow speeds into 4 wheel drive as well as Diff. Lock I am too damn lazy to stop and shift every time.
Kevin
1ArmBandit
55
Oct 14, 2015 09:03 PM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Bigtwin700
Sep 9, 2015 09:32 AM
