Adjustting Raptor Chain???
Old Sep 3, 2003 | 03:00 PM
Yam4Life660R's Avatar
Default Adjustting Raptor Chain???
I just got my 12T sprocket and I need to know how to adjust my chain properly?Also,how do I know when it's adjusted right?
Thanks guys,
James
Old Sep 3, 2003 | 06:26 PM
Need help pretty bad at this point.I'm fixing to install the gear but i'm still a little unsure about the chain adjustment.Please help if anybody knows.
Thanks guys,
James
Old Sep 3, 2003 | 06:38 PM
HackerHunter's Avatar
the sprocket didnt come with tension specs? there is a section on your owners manual that talks about chain adjustment and tensioning, but it might not mention how much to change if you went with less teeth.
take a look...
Old Sep 3, 2003 | 06:45 PM
No,all they gave me is a sprocket and a receipt.I'm fixing to run over to the shop and just adjust it as the owners manual says.
Thanks,
James
Old Sep 3, 2003 | 06:50 PM
HoundDog06's Avatar
Just dropping to a 12t will still be ok with the stock tension. Adjust it acccording to the OM specs.
~HoundDog
Old Sep 3, 2003 | 07:24 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
loosen the two large nuts that clamp the bearing carrier. (one top, one bottom) (be sure to loosen completely) (they have a tendency to snug up upon movement)
Loosen the locknuts on the adjuster bolts on top of the bearing carrier (one left, on right). Tighten them (BOLTS) simutaneously to push the axle back.
Use a tie down strap to keep the rear suspension compressed about 2/3 of the way. Tighten the chain to about3/4 inch play. tighten axle bolts. Snug up adjusters, and then tighten locknuts.
lube and ride
then check again
voila!!!
Firefighter400
Oct 8, 2022 06:38 PM
STLyamwar
Jul 25, 2020 04:44 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Zach509
Sport Quads
Aug 3, 2015 02:44 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
