Synthetic or regular 32 or 40 to 1?
Old Sep 3, 2003 | 11:46 PM
Whitedog's Avatar
Default Synthetic or regular 32 or 40 to 1?
So whats better Polaris synthetic or the good old Blue? I heard 32 to 1 for the blue & 40 to 1 for the Syn. But then again I heard 40 to 1 for the blue also? [img]i/expressions/face-icon-small-happy.gif[/img] THANX!!
Old Sep 10, 2003 | 03:04 AM
PmanX8's Avatar
Synthetic is supposed to be better for modded engines, ive never had a problem running the blue stuff, but my engine is stock. do you have the oil injection blocked off?, or is it still injected? because you cant run pre-mix if it is injected, but if you have the block off, than you are supposed to run 40-to-1 since its a liquid cooled 400. (someone please correct me if i am wrong)
Old Sep 10, 2003 | 10:04 AM
401's Avatar
401
I run the gold at 32:1.
Old Sep 10, 2003 | 10:09 AM
401's Avatar
401
Hey whitedog,how did you remove so much weight from your bike?
Old Sep 10, 2003 | 01:40 PM
Whitedog's Avatar
I removed: front diff, drive shaft, the guts in the hub, starter, battery, bat. box, all wiring, generator coil, litnd flywheel, shift linkage, floor boards, fan, bumpers, all rear brake stuff, chain guard, air box, oil injection and tank. Plus I cut the plastic. All I did was split weigh the front and the back on a bathroom scale so I may be off. About 190 up front, 180 on back.
Old Sep 10, 2003 | 01:42 PM
Whitedog's Avatar
Oh yea, I went into the tranny and removed anythng that didnt have with going foward in 2wd, and made a plate to cover the front output hole.
Alex G.
Sep 19, 2015 06:34 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Elkaholic
Sep 6, 2015 02:44 PM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
