removing scrambler ball joints?
Old Sep 4, 2003 | 10:08 PM
scrambler420's Avatar
Default removing scrambler ball joints?
how do i get the ball joints out?i thought the metal plate held them in but i guess not..thanks
Old Sep 4, 2003 | 10:41 PM
CED's Avatar
CED
Sometimes they are pretty tough.I used a slide hammer and heated the housing a little and they came right out.
Old Sep 4, 2003 | 10:50 PM
i was going to take the slide hammer to it but wasnt sure if thats what it took..thanks
Old Sep 4, 2003 | 10:51 PM
Farmr123's Avatar
The plate is there just for insurance, the joint is press-fit in the strut.
Old Sep 4, 2003 | 10:52 PM
thanks for the info..
Old Sep 5, 2003 | 01:25 AM
BigBadScrambler's Avatar
Here is the best way that I found do do it. Disconnect the a-arm from the ball joint. Then remove the retaining plate. Next reconnect the a-arm. Use a torch to heat up the ball joint. It is a good idea to have some eye protection on though because that grease can explode. Once you get it good and hot, use a pry bar and put it between the a-arm and btoom of the strut. Next pry up forcing the a-arm down and pulling the ball joint out with it. Works really slick. Then what I do is freeze the new ball joint, best if left in freezer overnight. Then use some Triflow or silicone spray to help get the new ball joint back in. You can use a deep socket to hammer it back in. Be careful though. You need just the right socket too. Hope this helps some
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Dec 15, 2015 03:59 AM
toonces
Aug 13, 2015 12:40 PM
toonces
Aug 12, 2015 06:42 AM
musselmark
Jul 17, 2015 02:40 PM
