raptor axle
Old Sep 5, 2003 | 08:24 PM
Fooch's Avatar
Default raptor axle
anyone know a trick for loosening the axle nut? I cant break it and I am trying to install my lonestar axle. Please help!
Old Sep 5, 2003 | 08:59 PM
sixsixT's Avatar
Default raptor axle
Did you loosen the set screws? I just put it in reverse with the engine off of corse and the tires on the ground and used a 24" pipe wrench, if you have someone the could hold the rear brake while you do this might help. If that doesn't work a little heat may be needed.
Old Sep 5, 2003 | 09:09 PM
Fooch's Avatar
Default raptor axle
Set crews? There are set screws on the stock axle nut?
Old Sep 5, 2003 | 09:19 PM
sixsixT's Avatar
Default raptor axle
Yea. Just on the first or lock nut one.
Old Sep 5, 2003 | 09:25 PM
Fooch's Avatar
Default raptor axle
I saw a little hoel in the nut, is there a little hex head bolt in there?
Old Sep 5, 2003 | 09:29 PM
sixsixT's Avatar
Default raptor axle
There's suppose to be, one on each side of the nut. 2 set screws total.
Old Sep 5, 2003 | 10:05 PM
Fooch's Avatar
Default raptor axle
I just checked it, dont I feel like a moron! thanks
Old Sep 6, 2003 | 03:29 PM
sneyeper's Avatar
Default raptor axle
Don't feel bad ... the first time I took mine off .... I had to ask the same thing ... just letting you know you are not the only idiot out there ... 8)
bmxatv10
Oct 14, 2022 06:23 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
