99 Sportsman - Changing Tire Size
Old Sep 8, 2003 | 03:17 PM
ghlacy's Avatar
Default 99 Sportsman - Changing Tire Size
I have a 99 sportsman with the factory tires and wheels. The fronts are 23x7x10 and the rear is 24x11x10. They are about worn out and I am going to replace them with a little more aggressive tire. This bike is 4x4. Can I put the same size tire all the way around or do I need to stay with the oem specs? I was thinking about 25" or 24". I don't want to go so big that I notice a drop in performance. I really like the new ITP mud lights. Would it help on weight if I upgraded to 12" wheels? Any help woulld be great. Thanks.
Graham
Old Sep 8, 2003 | 05:44 PM
highwayman's Avatar
Larger tires will lower the power your bike has and I think if you increase the tires proportionally (increase rear 1" do the front 1") I think if you maintain the same ratio it should be OK.
Old Sep 8, 2003 | 08:24 PM
upnort's Avatar
According to my ITP apps the 99 SP500 should have had 25x8x12 F and 25x11x10 R on 12x7 F and 10x8 R rims. (96-02 are this size) 25 mudlites would be ok. Do not go with 26 or above as the fronts are 10" wide and will rub.
Old Sep 8, 2003 | 08:33 PM
highwayman's Avatar
I am assuming you have a 335 like me which by all acounts in under powered so when I chang tires I will probably keep the same diameter but go with an 8" wide tires on the front to give a greater tire selection.
Old Sep 9, 2003 | 09:11 AM
ghlacy's Avatar
Yes, I do have a 335. I think I am going to go up 1" from the stock size. How bad will my spedo be off? Is there any way to recalibrate it?
Thanks.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
Mphillips
Jul 29, 2015 08:53 PM
rcappie4
Jun 13, 2015 05:28 PM
BOBATVN
May 26, 2015 07:34 AM
lablover
Mar 12, 2000 04:03 PM
