pipe for yzf450
Old Sep 9, 2003 | 12:06 AM
jcal's Avatar
Default pipe for yzf450
what pipe is everyone running? or what pipe would you run?
Old Sep 9, 2003 | 12:12 AM
Yamaha660R's Avatar
heard good things about Curtis Sparks Racing pipes
Old Sep 9, 2003 | 12:15 AM
wshrdskin's Avatar
Every fast quad I see in my part of the country (well alot of them anyway) run the Curtis Sparks pipe. This would include all of the faster YFZ's I've seen.
Old Sep 9, 2003 | 12:46 AM
killerkx327's Avatar
everyone is running curtis sparks pipes becuase they were the first pipes that were readily available.
so far everyones pipes are making about the same HP. with the same mods and same jetting. it's not really about who make the most power from thier pipe but where it makes the most power. you want a pipe that makes good strong broad powewr, not one that peaks 2 hp more then the other guys.
i'm using a stock head pipe, and a GYT-R carbon fiber slip on, and so far i have dynoed four other pipes and none of them have made any more power then my GYT-R slip on. and they were all jetted properly dynoed the same day on the same dyno on the same machine with all the same mods.
the stock header and slip on setup made more power then any of them above 8500pm's.
so it pretty much doesn't matter which one you get becuase they are all within .5-1of each other.
Old Sep 9, 2003 | 01:18 AM
YFZn's Avatar
IM with Killer. I also chose the GYT-R, and couldn't be happier. We dynoed it with a Sparks on the same bike and set up and the numbers where the exact same.
Old Sep 9, 2003 | 09:48 AM
selector's Avatar
I'm running the Sparks but will be swaping over to a full Thunder Alley system as soon as it's done being built.
I'll dyno the machine again (w/ the TA) and compare the results.
selector
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
