01' Recon gas tank trouble
Old Sep 9, 2003 | 08:48 PM
ceriph's Avatar
Default 01' Recon gas tank trouble
I just bought a 01' recon and am brand new to the atv world. I have a problem with the gas tank, when it is in the ON pos it will not run but it is fine on the reserve tank. I am not the most mechanically inclined person but I can do a little. Any suggestions on where to start with this problem? Any help would be greatly appreciated.
Thanks
Old Sep 9, 2003 | 11:15 PM
Coyotechaser's Avatar
Try filling the gas tank up all the way.
Old Sep 10, 2003 | 03:30 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The ON and RESERVE are just 2 inlets with different heights. ON is higher, and RESERVE is lower. You probably have someting clogging the ON inlet. Pull the hose off the carb and drain the tank. Then, with the valve in the ON position, blow air back up the line to try to dislodge the blockage.
It would be best to remove the tank from the bike, and rinse it a few times to get the crud out, or it will probably just clog again. Just remove the plastic around the tank, and you will see a couple of bolts holding it in. It's a good idea to rinse you tank periodically anyway.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
wrencher82
Sep 30, 2015 04:27 AM
2many2ride
Sep 27, 2015 04:35 AM
Clint Russell
Sep 25, 2015 03:20 PM
