ANY GOOD MECHANICS OUT THERE????????
Have you check to see if you got mud/water behing the start button causing it to stick a little bit?? I'm sorry bur that's the only other thing that comes to mind.
Mike
Mike
yes that's possible. they can 'weld' themselves together briefly. to see if your starter button is causing the problem then pull the control wire off immediately after it starts. if the starter shuts off immediately then it's getting voltage from the switch. if it doesn't then it's probably the relay.
if its an intermittent problem thats usually when they stick. The current load will semi "weld" a corroded, warn or dirty contact pad together internally and not let it release.
Check the button like 620 says since its easiest and the cheapest to do, it should probably be cleaned anyhow.
