ODB I need the formula for the front diff shims
Old Sep 10, 2003 | 05:40 PM
CatKrazy's Avatar
Default ODB I need the formula for the front diff shims
Do i need to know what the value is for the pinion?? I sure hope npot cause it is a son of a gun to get out.
im using my stock front gear housing stock pinion,stock gear case cover and a new ring rear"unlocked for hunting purposes" i will put my locked diff back in when hunting season is over
send me the formula to follow i lost my copy of it. Thanks
you stil have my email?
wmff82@aol.com
Old Sep 10, 2003 | 05:50 PM
CatKrazy's Avatar
ODB
is the value stamped or etched on the pinion like on the housing and etc.???
Old Sep 10, 2003 | 05:59 PM
Olddirtybastard's Avatar
I will check my files for the formula and send it to you. If your stock ring gear has the markings "OO" on it, and your new ring gear has "OO". Use the same shims. If they are different, you will need the formula.
The pinion shims do not have be changed unless you change the housing.
Old Sep 10, 2003 | 06:02 PM
The values are etched on the housing and the gears.
Old Sep 10, 2003 | 06:15 PM
CatKrazy's Avatar
cool........cool...let me know about the fomula..thanks
Old Sep 10, 2003 | 06:26 PM
CatKrazy's Avatar
well i can tell you that the new one says...34077 stamped in at the bottom and if you look at it the same way at the top has 01 stamped or etched in it. i just hope my stock one has 01 on it as well
Old Sep 10, 2003 | 06:52 PM
I sent you a PM.
Old Sep 11, 2003 | 11:04 PM
maximus's Avatar
glad to here from you catcrazy, did not know what happened to you
Old Sep 11, 2003 | 11:50 PM
CatKrazy's Avatar
AHHHHHHHHH, i have always been just prowlin around the corner oh grasshoppa!!!
Old Sep 12, 2003 | 01:50 PM
voodoo's Avatar
:] I knew you werent far...
