cdi box
Old Sep 10, 2003 | 11:33 PM
warriorwasfun's Avatar
Default cdi box
if a cdi box goes out will you still have a spark at the plug?
Old Sep 11, 2003 | 01:22 AM
Mrmonk's Avatar
Default cdi box
If your ignition fails then you can't have a spark. The spark goes from your igntion to the wire to the plug.
Old Sep 16, 2003 | 11:05 PM
Default cdi box
Old Sep 17, 2003 | 07:51 PM
Ronnnnn's Avatar
Default cdi box
starts in the stator, travels to the cdi box, then out to the coil and finishes strong at the spark plug.
Old Sep 17, 2003 | 08:19 PM
RacinJason's Avatar
Default cdi box
I have seen bad CDI units that still spark...whats the problem?
With elec problems you need to use an ohm meter and spec out the stator
pu coil
ignition coil
if these all test within factory specs replace the CDI...there are no good ways for the average person to check a CDI
