Banshee coolant reservoir question
Old Sep 13, 2003 | 12:45 PM
Turtler's Avatar
Default Banshee coolant reservoir question
I have a friend of mine that bought Toomey T5 pipes for his banshee. In the assembly instructions, Toomey tells you to remove the coolant reservior. I think they do this because their pipes interfere with the reservoir. Removing the reservoir also seems counterintuitive because the engine runs hotter. Have any of you cobbed together a bracket for the reservoir, or have you had sucess keeping the engine cool without the reservoir? Any input would be appreciated.
Old Sep 13, 2003 | 03:12 PM
BlackWidow's Avatar
I have not had any experience with this personally but I do not think that this would have any effect on actual cooling capability. The reservoir's purpose is to keep the radiator full to the top... it has no effect on actual cooling. If the engine gets too hot it pushes some coolant out and pulls the coolant back in when it cools down.
Old Sep 14, 2003 | 12:02 AM
Grounded's Avatar
Leave it on there if you can, I used clamps to hold mine in place with small slits in the plastic under the seat.
Old Sep 14, 2003 | 02:22 AM
DunePilot858's Avatar
The reason Toomey tells you to remove the overflow bottle is because of their one into two filter setup. If you do not remove the airbox you don't need to remove the overflow bottle.
essonlaker
Sep 10, 2015 01:12 PM
cornermike
Sep 10, 2015 08:30 AM
Bigtwin700
Sep 9, 2015 09:32 AM
Rooky
Sep 9, 2015 03:16 AM
Kenidah
Sep 7, 2015 07:50 PM
