Pivot bolt driver size?
Old Sep 13, 2003 | 02:25 PM
MudStud's Avatar
Default Pivot bolt driver size?
Before I take the swing arm off I want to get the right size impact... what size socket to get??
I also need to get the 36mm for the hub...
Old Sep 13, 2003 | 04:35 PM
crashnburn's Avatar
30mm, its the same as the front sprocket nut.
Old Sep 15, 2003 | 12:56 PM
hinglbyds's Avatar
It's 30mm. Make sure you don't try to turn the right side, it's crimped. You have to use a 30mm wrench and a 30mm socket on the left side to break the double nut loose. Then you can hold the right side to remove the nuts on the left side.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
akguy31
Aug 31, 2019 04:34 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
