11:1 piston & exhaust only?? Worth it??
Old Sep 15, 2003 | 03:22 PM
Flynbryan's Avatar
Default 11:1 piston & exhaust only?? Worth it??
Will I notice an improvement from the 11:1 piston w/o a cam or will I need the cam as well to get any gains from the higher compression piston? I plan on getting an aftermarket slip on(either gyt-r or white bros E-series, leaning more towards the white bros.),but didn't know if it would be worth the extra $$$ to buy a high comp. piston unless I've had other motor work done as well? I found some results from the search function but no one addressed this question directly.....Thanks in advance for your responses.
Old Sep 15, 2003 | 04:38 PM
Mrmonk's Avatar
Yes, you would benefit, but you would not take full advantage of the additional mods w/o the cam. Save a bit more and get the cam. But then again, your additional compression and cam would probally necessitate getting the head ported...and then haha. Seriously though, the mods work best as a package.
Old Sep 15, 2003 | 05:04 PM
JakalWarrior's Avatar
Youll probably get alot of torque instead of alot of top end.
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Sep 10, 2015 01:56 AM
Bigtwin700
Sep 9, 2015 09:32 AM
atvcollector
Sep 8, 2015 05:11 PM
Myronh
Sep 8, 2015 11:27 AM
