Rappy guys with extd. swingarm
Old Sep 16, 2003 | 12:59 AM
wildchild660R's Avatar
Default Rappy guys with extd. swingarm
What do you guys use for chain sliders. I dont want a bunch of slop in mine when I put it all back together. Also while where at it was size/kinds of chains are you running?
Old Sep 16, 2003 | 01:16 AM
RepTaR660r's Avatar
hell i just orderd a +6 tucker and that didn't even come to mind... hope the stocker works... ???
Old Sep 16, 2003 | 01:28 AM
2fiftyX's Avatar
Stocker works just fine on my +2 Tucker.
Old Sep 16, 2003 | 01:32 AM
Are you guys running a skid plate though? Im not and I got my stock swingarm extended so the mounting is way off now ... (didnt have the bucks for the tucker unfortunately)
Old Sep 16, 2003 | 01:44 AM
2fiftyX's Avatar
Yes, I am also running a GYTR swing skid. Just had to let Jeremy at Tucker know I wanted mounting tabs.
Old Sep 16, 2003 | 02:00 AM
bad350twin's Avatar
im running a +4 eyeball engineering on my 01 686 with no slider and a sidewinder chain
Old Sep 16, 2003 | 08:12 AM
garyc660R's Avatar
My stock slider is working fine on my +4 Tucker. You must specify upon ordering that you need the skid plate tabs. You could probably fab something up too hold a skid on with the extended stocker.
Old Sep 16, 2003 | 08:51 AM
Treeshot's Avatar
+4 LS, no skid plate and I'm using a banshee style chain guide and rollers. As for chain I just put a chain extension on the stock one.
Reptar you probably already thought of this but with a +6 swing arm I'm pretty sure your gonna need a longer brake line and I know you will need a longer chain. As for sliders you should be able to call Jeremy and ask.
Old Sep 16, 2003 | 09:48 AM
RAPTORAZ's Avatar
+4.5" JTM extension. stock skidplate, rollers, and guides. 106 link DID X-ring chain. No problems here.
Old Sep 16, 2003 | 09:51 AM
garyc660R's Avatar
AZ.....how did you go about using the skidpate with the JTM set-up? Fab up some extenders from the stock bolt holes?
