ignition timing
yes more timing will help. If you buy from jim jr. at russel karting, he can put in any 10 curves you want. the handlebar switch can be used to switch between curve number 1 and one of the other 9 curves. Each curve can have it's own rev limit. Jim can re-program the curves later if you want to modify them after testing. there are two models available, one with an ignition kill input for clutchless full throttle shifting.
