$400 Turbo!
Old Sep 17, 2003 | 06:34 PM
ScoobyDFW's Avatar
Default $400 Turbo!
The turbocharger itself (not a whole bolt-on kit) I'm currently running on the DS can be bought for as low as $400 brand new!
Old Sep 17, 2003 | 06:46 PM
Johnnyairtime's Avatar
Default $400 Turbo!
Scoob..... do you mind elaborating???
It's like you just dangled the carrot out there..... and left us hangin'!!! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 17, 2003 | 06:55 PM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Default $400 Turbo!
What would you estimate the cost of turbocharging a DS? What would a turbo normally run and why is this one cheap?
Old Sep 19, 2003 | 02:10 AM
fixit01's Avatar
Default $400 Turbo!
I know that I'm WAY out of place here....I own a sand rail but mostly Snowmobile. Can you tell me where to find info on the $400 turbo? I'd like to put one on my '02 Polaris RMK 800 (twin)! I did a Yahoo search about an hour ago and this is where I ended up.
Thanks,
John
Old Sep 19, 2003 | 03:33 AM
jetsnow600's Avatar
Default $400 Turbo!
hey, its fixit john from snowest. BTW, this is 03mc900. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 19, 2003 | 08:35 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Default $400 Turbo!
There are a number of turbos in the 400$ range just go to your local turbo shop and discuss your plans and they should be able to set you up with a turbo in that range!!
Old Sep 19, 2003 | 02:25 PM
biggerisbetter's Avatar
Default $400 Turbo!
Scooby,
Tell me what would be a safe ,and reliable boost for that particular turbo? I know you run 8:1 and run high boost, but if I drop down to say 11:5:1 would 7-8 lbs of boost be to much still?? Now that I have this FI system , I think a turbo woul dbe alot easier to make work.
Call me if you have time (580) 821-1200.
bigger.
Old Sep 19, 2003 | 02:56 PM
ScoobyDFW's Avatar
Default $400 Turbo!
I was able to run around 18psi on alcohol with stock 9.7:1 static compression ratio piston (about the time rings started breaking).
boost pressure ratio = (14.7psi + boost)/14.7 = 2.22 @ 18psi of boost
static boost compression = boost pressure ratio * static compression ratio = 21.5 @ 18psi of boost and static CR of 9.7:1
if you want to run 21.5 static boost compression, work backwards.
max boost = [(21.5/static CR) * 14.7] - 14.7 = 12.78psi @ 11.5:1 static ompression ratio
or use calculator here: http://www.turbofast.com.au/TFcompB.html Use 100% VE for static calculations.
your fuel pressure regulator would probably have to be referenced to boost pressure like mine.
you might have to remove some of the extra ignition timing you have and/or use vortex CDI.
Old Sep 21, 2003 | 11:13 AM
fixit01's Avatar
Default $400 Turbo!
Hi Sean (Jetsnow600),
Man you spend too much time at the computer! [img]i/expressions/face-icon-small-smile.gif[/img] I'll have you beat the next time we drag. I just picked up a PSI Genesis 925 for the Polaris. You better get some pipes on the cat quick.
AZSAND, We have no turbo shops in this little "hodunk" town of Winnemucca. Does anybody have a phone # for their local shop and I'll phone order something????
Thanks,
John
Old Sep 21, 2003 | 05:19 PM
jetsnow600's Avatar
Default $400 Turbo!
hey john, check into the reno area, i am sure there are some shops there. 925, ha. I have an 1150 on the way for my cat [img]i/expressions/face-icon-small-wink.gif[/img] lol, jk.
ReconBayou
Oct 31, 2022 05:37 PM
Logan Collins
Sep 5, 2015 08:03 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
DSBUDDY
Dec 28, 2001 01:43 AM
