Some cleaning led to powder-coating....
Old Sep 19, 2003 | 12:36 AM
Gaskett's Avatar
Default Some cleaning led to powder-coating....
Well it started as a good cleaning, but as soon as I got it apart, I threw them into the sand-blast cabinet then I broke out the powder coater.
So far it's just the hubs and the spindles, but it soon will be all the brake calipers, tie-rods, rims... yada yada yada....
Here's the pics:
Spindle
Hub
Spindle & Hub
Did all the work in the garage...
When you have to take a vacation because you already have 60 days of it saved up.. it causes you to do some crazy things.....
Old Sep 19, 2003 | 01:00 AM
Lason's Avatar
WOW, looks nice. Did you use the eastwood powdercoating setup? Also did you powdercoat the hub grey or just blast it? Anyway it looks REAL nice and I may be doing the same this winter except I will be doing the frame, a-arms, swingarm etc so it may just pay off to have my local powder coat shop do the whole thing.
Old Sep 19, 2003 | 01:24 AM
Bajaboy650's Avatar
Yeah It looks great. I am also curious what setup you are using and about how much did it set you back, If you dont mind me asking.
Old Sep 19, 2003 | 01:29 AM
MudStud's Avatar
I want a powder coater!!!!!
Dang that looks good.. I would do just about every part...
Old Sep 19, 2003 | 02:12 AM
Lason's Avatar
I have seen people use this setup along with a conventional electric oven and have great succes but you are limited to what would fit in the oven..........
Powder Coating setup
Old Sep 19, 2003 | 11:42 AM
Gaskett's Avatar
Powder coating setup... $59.99 (harbour freight has them on sale)
Extra oven for the garage... $50 (out of the classifieds)
The material I get from a local powder coating place 2lbs about $10
So, start up costs were about $120.00 (I already saved that amount)
I can powder coat anything that fits in the oven, only takes 20 minutes of bake time.
You don't have to use an oven either, they sell UV lights that create the heat too, so you can use that to cure the powder on larger areas....
The hubs I didn't want to dis-assemble (bearing and seals were already new). So I bought a can of Grey Hammer Paint from Lowes for $4.97. It's very tought stuff, plus it will clean up easier than the plain ole metal finish on the hubs.
Glenn
Old Sep 19, 2003 | 01:10 PM
CrazyWhiteDude's Avatar
I would like to get that setup too. 1 question I have though, does it smell really bad when you bake the powdercoated part?
Old Sep 19, 2003 | 03:16 PM
buttfungus's Avatar
Nice Glenn![img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 19, 2003 | 03:51 PM
BaJaBoy03's Avatar
Is this the one?
Powder Coater
Old Sep 19, 2003 | 07:45 PM
BabyMoose's Avatar
I have heard for some really big items that you could hook up a welding machine and reverse the flow and that would bake the powder on. Has anybody done this or even know if it is true??? I have no idea
Thanks!!!
