Kimpex Grip Heaters
Old Sep 18, 2003 | 10:07 AM
yoda's Avatar
Default Kimpex Grip Heaters
Does anybody have any feedback on the Kimpex grip heaters? I want to install a pair but every dealer I talk to suggest to use the Hot Grips instead. I don't like the feel of the Hot Grips. I like that I can pick my own grip if I use the Kimpex ones.
Also, if you have a set, how hard where they to install? Are they glued to your handlebars with the same glue as your grips?
Old Sep 21, 2003 | 11:56 PM
cluby's Avatar
well your right you should be able to get the ones you want. IF your dealer won't order them there not a good dealer. Have you thought about putting on snowmoblie hand grip heaters. and you can use the stock grips just get a three way switch and some wire and connectors. I think that Polaris has the hotter heaters if that helps you I put ski doo ones on mine and they work fine wish I would have put a thumb warmer on but that's a later project.
shimanok2
Jan 29, 2016 07:37 PM
black_thunder
Sep 7, 2015 01:24 AM
Polarisman1123
Aug 13, 2015 08:13 AM
erntee61
Aug 9, 2015 02:54 PM
mdrkcckv
Jul 22, 2015 09:10 AM
