installing fuel filter
Old Sep 19, 2003 | 07:26 PM
javex's Avatar
Default installing fuel filter
i finally got around to buying a fuel filter (3011 NAPA) and i think it is just too long. somebody recommended this filter in a post. if i had to install this filter vertically, i think i would have to use alot of fuel line and a route the line in a funky way. it is ok to have a long fuel line from the gas tank to the carb?
Old Sep 19, 2003 | 07:28 PM
racerx5x5's Avatar
Is it bad to have verticlly mounted ?
Old Sep 19, 2003 | 07:31 PM
javex's Avatar
i believe somebody said this type of fuel filter (clear plastic with paper element) needs to be install vertically..
Old Sep 19, 2003 | 08:07 PM
KenDS's Avatar
I believe it was one of my earlier posts that you are referring to. The outside diameter of that filter does make it a little difficult to mount cleanly, but it will work. It doesn’t have to be perfectly vertical just make sure that the outlet side is lower than the inlet side. What this does is creates a fuel reservoir to compensate for the filter restriction.
Old Sep 19, 2003 | 10:24 PM
javex's Avatar
thx ken .. i will mount in the most vertical position i can, but i think it will have close to a 45 degree tilt on it.. at least the outlet side willl be lower .. hope it will work great
Old Sep 20, 2003 | 06:43 AM
Hightower's Avatar
I just had some major suffering this week due to a paper element fuel filter not flowing well enough. Two weeks ago I removed my anodized aluminum filter that has a cleanable stone element inside, and installed a transparent plastic filter with a paper element. I thought the transparent idea was great. So then my first ride with it my bike would fall on its face going from 3/4 to full throttle. Seems the bowl would run out faster than the filter could replenish. I removed the new filter, through it as far as I could, and all my problems were gone. I put my stone element back on.
The filter was indeed mounted perfectly verticle, gravity was in its favor. I'm not slamming all paper filters, but this one I got from Carquest is no good for gravity feed. Just be aware, if symptoms depelop you know where to look first.
Old Sep 20, 2003 | 10:07 AM
DSJOBBER's Avatar
Yep. I too have the anodized stone element filter. Works great. I have it mounted next to the carb.
cody500ho
14
Aug 14, 2015 05:03 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
