pro desing kill swich help
Old Sep 21, 2003 | 02:33 PM
raptorblasterracer's Avatar
Default pro desing kill swich help
anyone know a site that shows u how to install a pro desing kil swich. i know one wire needs to be grounded and the ohter gets taped into another wire...but which one. i got a yfz450.
Old Sep 21, 2003 | 05:55 PM
miniuncle's Avatar
Bottom plug on the CDI is a all white wire. Hot wire(long wire) goes there, and the ground wire(Short wire) gets grounded to the frame. Should have no troubles, mine works perfectly.
Old Sep 21, 2003 | 08:38 PM
alright and where is the cdi unit on the yfz
Old Sep 21, 2003 | 09:08 PM
miniuncle's Avatar
It is the square box covered with a rubber boot attached to the frame under the front fenders it has three plugs (if I remember correctly) going into it. The white wire is on the bottom plug. The boot and CDI will slided off the tab on the frame.
Old Sep 21, 2003 | 09:54 PM
thanks so much ill try it after skool tomarrow.....i should sodern them right
Old Sep 21, 2003 | 09:56 PM
should i take the front plastic off to do thhis
Old Sep 22, 2003 | 09:06 PM
miniuncle's Avatar
Well how did you do ?
EIF
Apr 20, 2017 07:15 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Halffast17
Sep 11, 2015 02:30 PM
alzgarvin
Sep 11, 2015 08:53 AM
Albertaboyy
Sep 9, 2015 09:51 AM
