87 Kawasaki Bayou
Old Sep 22, 2003 | 03:22 PM
bayoubuster's Avatar
Default 87 Kawasaki Bayou
Having problems starting my 87 bayou 300.....the starter switch just clicks....battery seems alright and already changed out the starter switch..checked all fuses...lights work
Thanks
Old Sep 23, 2003 | 10:45 AM
KAWIMECH's Avatar
TRY bypassing your netrual relay switch, up under the back side of the mach there is a little black round relay there are two black wires going into it take a paper clip and cut it and jump it across the two black wires to bypass the relay, if that dosent work jump across the starter solenoid with a screwdriver this will tell u if the starter turns over, its good so is the batt so is the ground cable.
Old Sep 23, 2003 | 09:58 PM
Hey,
When I jump by the starter solenoid the starter switch clicks faster and I can hear the starter slowing turning. Is this weak battery or bad starter?
Thanks
Old Sep 24, 2003 | 10:17 AM
KAWIMECH's Avatar
sounds like the batt is your problem
Old Oct 3, 2003 | 12:39 PM
Hey,
My battery was fried, but so is my starter, upon opening the starter for inspection the end with the magnets was full of grease. Is this normal or a problem. A friend said it should be clean of any fluids on that end.
Thanks
wendal
May 9, 2024 09:29 PM
ReconBayou
Oct 16, 2019 02:24 AM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
rcappie4
Sep 9, 2015 07:04 PM
