O-ring vs X-ring chains ...
Old Sep 23, 2003 | 11:42 PM
wildchild660R's Avatar
Default O-ring vs X-ring chains ...
For you people that run sand only what kind of chains do you run? Is there a need to run a O-ring or to run a X-ring? What about just a cheaper normal chain?
Old Sep 24, 2003 | 01:29 AM
HoundDog06's Avatar
Regina 520 o-ring works for me.
~HoundDog
Old Sep 24, 2003 | 01:38 AM
Mr45auto's Avatar
I run a non O ring regina 520 gold. It's supposed to not have as much drag as an O ring chain and if you're keeping it clean and lubed for sand I dont really see a reason for the O ring. In trail riding I belive an O ring would be better to keep things lubed.
Old Sep 24, 2003 | 03:19 AM
rockrider's Avatar
O-ring chains are the only way to go if you trail ride and hit mud and water. If you live where it is dry then a non o-ring chain will probably last. A lot of MX guys run non o-ring chains just because they free up a little bit more power. But, the conditions they ride in are kind of controlled compaired to Jow Blow the average trail rider.
Old Sep 24, 2003 | 09:06 AM
selector's Avatar
I run DID ERTs on everything that I replace chains on. I still have my o-ring parts (and a couple masters) for the YFZ and will probably use it again. The DID ERT is a very good non o-ring chain.
That's one of the nice things about riding in Utah - very dry for the most part. At least where I ride.
selector
Old Sep 24, 2003 | 12:06 PM
I was thinkin like what Mr45 said about houw if your only gonna ride in the sand, which I am, then whats the use for the O-ring right? I think I ll go with Mr45s chain because we ride in the same area and conditions and if his is holdin up my should also.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
