Problem with Fuel Leaking
Old Sep 24, 2003 | 02:00 PM
duneDS650's Avatar
Default Problem with Fuel Leaking
I put an IMS 5-gal desert tank on my DS and now fuel drips out of the lower vent hose. It's just a drip so I didn't worry about it until I saw the size of the hole in the brass vent tube. It's so small that it seems like the bowl could be totally flooded and the vent would only drip.
Anyone else have this problem? I cleaned the needle valve and seat, but it didn't help.
I think did does this regardless of the amount of fuel in the tank. During a race the motor was bogging on-and-off, I think it was flooding due to the needle not shutting off the flow.
Thanks for any suggestions.
Old Sep 24, 2003 | 05:25 PM
TyreSpinner's Avatar
Which carb are you using.
That definetly sounds like floats or needle valve issues..
Old Sep 24, 2003 | 08:58 PM
duneDS650's Avatar
It's the stock Mikuni BSR 42. The dealer want's $41.95 for a replacement needle and seat. I'd hate to buy one and have it not be the problem. Does the rubber on the seat get old and not seal or something?
Old Sep 24, 2003 | 09:38 PM
DSJOBBER's Avatar
Myself and Joshie Poo have the same problem. Our carbs will drip while the quad is sitting yet they run fine. Im not too sure what the deal is but Josh's started first and now mine is doing it as well. It has caused the paint on the swingarm to change colors. Josh has completly rebuilt his carb to no avail. Any ideas?
Old Sep 24, 2003 | 10:02 PM
DogS's Avatar
Sounds like bad float to heavy or inproperly ajusted.
Old Sep 25, 2003 | 01:29 AM
jiminok's Avatar
Check the brass bowl drain screw...loosen it up and then reseat it.
Old Oct 7, 2003 | 09:37 PM
subnuke3363's Avatar
Same problem - torqed the screw down and it stopped. still have a problem every now and then. probably going to upgrade the carb later anyway.
Old Oct 8, 2003 | 12:07 AM
SANDMAN430's Avatar
seems demonds had this problem and he jb weld the over flow shut i could be wrong it was a long time ago.
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
traumajunkie
Jul 5, 2015 03:03 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
