Clutch Springs For Raptor
What is a good set of springs for the raptor clutch? I have a new clutch and its about 2 months old and its starting to slip bad when taking off in 2nd. I dont want to really be pulling on my clutch that hard but still want it to grab pretty good.
Thanks
Thanks
I think you can better go with the barnett clutch kit and Hinson clutch basket and pressure plate. Hinson makes the products for GTYR.
http://www.hinsonracing.com
http://www.barnettclutches.com
I purchased the Barnett clutch kit but I dont think I got the Heavy duty springs because I didnt feel any difference. I believe the clutch should still be good.
Another thing I just found out, the spring that is mounted on the top of the clutch housing that pulls back the clutch lever is loose. How is that?? Do those wear out? And do you think that may be my reason why the clutch started slipping?
I wrapped it around more and now it has tension on it but it still slips in take off.
